주요 콘텐츠로 건너뛰기
Logitech Dual Action Joystick Replacement
필요한 것
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: 1 단계, 이미지 1개 중 1개
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: 2 단계, 이미지 3개 중 1개 Logitech Dual Action Joystick Replacement, Opening the controller: 2 단계, 이미지 3개 중 2개 Logitech Dual Action Joystick Replacement, Opening the controller: 2 단계, 이미지 3개 중 3개
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: 3 단계, 이미지 2개 중 1개 Logitech Dual Action Joystick Replacement, Replacing the joystick: 3 단계, 이미지 2개 중 2개
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
결승점
다른 24명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brian Neuman
회원 가입일: 01/20/15
1,082 평판
안내서 3개를 작성함
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G4
4 회원들
안내서 5개를 작성함
5가이드 댓글
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - 답글
will the buttons still work if you put it all back?
Atsuku - 답글
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - 답글
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 44
지난 30일: 197
전체 시간: 12,991
