주요 콘텐츠로 건너뛰기
Logitech Dual Action Triggers Repair
필요한 것
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: 1 단계, 이미지 1개 중 1개
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Triggers Repair: 2 단계, 이미지 2개 중 1개 Logitech Dual Action Triggers Repair: 2 단계, 이미지 2개 중 2개
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
  3. Logitech Dual Action Triggers Repair: 3 단계, 이미지 1개 중 1개
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
  4. Logitech Dual Action Triggers Repair: 4 단계, 이미지 3개 중 1개 Logitech Dual Action Triggers Repair: 4 단계, 이미지 3개 중 2개 Logitech Dual Action Triggers Repair: 4 단계, 이미지 3개 중 3개
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
  5. Logitech Dual Action Triggers Repair: 5 단계, 이미지 3개 중 1개 Logitech Dual Action Triggers Repair: 5 단계, 이미지 3개 중 2개 Logitech Dual Action Triggers Repair: 5 단계, 이미지 3개 중 3개
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
  6. Logitech Dual Action Triggers Repair: 6 단계, 이미지 2개 중 1개 Logitech Dual Action Triggers Repair: 6 단계, 이미지 2개 중 2개
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
  7. Logitech Dual Action Triggers Repair: 7 단계, 이미지 3개 중 1개 Logitech Dual Action Triggers Repair: 7 단계, 이미지 3개 중 2개 Logitech Dual Action Triggers Repair: 7 단계, 이미지 3개 중 3개
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
  8. Logitech Dual Action Triggers Repair: 8 단계, 이미지 1개 중 1개
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brian Neuman
회원 가입일: 01/20/15
1,082 평판
안내서 3개를 작성함
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G4
4 회원들
안내서 5개를 작성함
4가이드 댓글
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - 답글
Where can I get conductive pads for this?
Ginga - 답글
RADO rakotonatoandro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 124
전체 시간: 11,223
