주요 콘텐츠로 건너뛰기
Logitech Extreme 3D Pro Disassembly of the handle
필요한 것
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: 1 단계, 이미지 1/1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: 2 단계, 이미지 1/1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: 3 단계, 이미지 1/2 Logitech Extreme 3D Pro Disassembly of the handle: 3 단계, 이미지 2/2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Emanuel Canela
회원 가입일: 01/25/18
1,297 평판
안내서 7개 작성하였습니다
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G1
4 회원들
안내서 7개 작성하였습니다
댓글 2개
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - 답글
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 38
전체 시간: 3,442
