주요 콘텐츠로 건너뛰기
Logitech Extreme 3D Pro Main Joystick Spring Replacement
필요한 것
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: 1 단계, 이미지 1개 중 1개
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 3 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 3 단계, 이미지 2개 중 2개
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: 4 단계, 이미지 1개 중 1개
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 5 단계, 이미지 3개 중 1개 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 5 단계, 이미지 3개 중 2개 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: 6 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: 6 단계, 이미지 2개 중 2개
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 7 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 7 단계, 이미지 2개 중 2개
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 8 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the Spring
    • The spring will be covered in lubricant.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Emanuel Canela
회원 가입일: 01/25/18
1,369 평판
안내서 7개를 작성함
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G1
4 회원들
안내서 7개를 작성함
5가이드 댓글
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - 답글
Where can I find a replacement spring?
ande3224@bellsouth.net - 답글
Anyone found a source for replacement springs?
Chandler - 답글
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - 답글
In logitech 3d extreme, the middle joystick loosens over time, there is a slight gap when turning it to the right and left. Is there a solution to this?
haşim kadir yüksel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 43
지난 30일: 176
전체 시간: 14,369
