주요 콘텐츠로 건너뛰기
Logitech Extreme 3D Pro USB Cable Replacement
필요한 것
  1. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the handle: 1 단계, 이미지 1개 중 1개
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro USB Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro USB Cable Replacement: 3 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro USB Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the base: 4 단계, 이미지 1개 중 1개
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro USB Cable Replacement: 5 단계, 이미지 3개 중 1개 Logitech Extreme 3D Pro USB Cable Replacement: 5 단계, 이미지 3개 중 2개 Logitech Extreme 3D Pro USB Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: 6 단계, 이미지 2개 중 1개 Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: 6 단계, 이미지 2개 중 2개
    • Carefully pull from the plug head straight up.
    • It may require some force to remove the cable. However be careful not to damage the wires.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Emanuel Canela
회원 가입일: 01/25/18
1,369 평판
안내서 7개를 작성함
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G1
4 회원들
안내서 7개를 작성함
6가이드 댓글
What type of replacement cable do I need? Where can I purchase it?
Tom Tidbury - 답글
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Clayton Noyes - 답글
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Jordan Stéphane Martinez - 답글
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
William McCall - 답글
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
Dylan Brasier (Grim) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 2,973
