주요 콘텐츠로 건너뛰기
Logitech G1 Optical Mouse Scroll Wheel Replacement
필요한 것
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 1개 중 1개
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: 3 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: 5 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: 6 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 6 단계, 이미지 2개 중 2개
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: 7 단계, 이미지 2개 중 1개 Logitech G1 Optical Mouse Scroll Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: 8 단계, 이미지 1개 중 1개
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
wooseok yang
회원 가입일: 01/19/21
358 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 36
전체 시간: 2,027
