소개
Wenn dein Logitech G27 nach der Kalibrierung nicht mehr reagiert, musst du möglicherweise den optischen Encoder tauschen. Der optische Encoder ist ein kleines Bauteil, das die Raddrehungen in elektrische Signale für den Computer umwandelt. Das zu ersetzten ist nicht schwer, braucht aber viel Geduld, weil du sehr viele Schrauben lösen musst. Stelle sicher, dass das Lenkrad nicht angeschlossen ist, bevor du beginnst.
부품
지정된 부품이 없습니다.
Entferne die sechs grauen 25mm Sechskantschrauben mit einem 4mm Inbusschlüssel.
Hebe das Rad vorsichtig an, trenne es jedoch nicht vom Rest des Geräts.
Fasse vorsichtig den großen 7-poligen Stecker unter der Platine und ziehe ihn ab.
These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
This works for the G27, not sure about the G25 or any other wheels.
Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
@alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
Okan Akgül - 답글
okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
Where i can Buy the 7 pin cable for Main board please
Hey guys!
i broke the 7 pin cable anyone know where can is buy it? Thanks
Drehe das Gehäuse wieder um und entferne die obere Gehäusehälfte, so dass die meisten Bauteile des Lenkrads sichtbar werden.
Lege die obere Gehäusehälfte zur Seite, du brauchst sie erst beim Zusammenbau.
Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
Oula Kuuva - 답글
Entferne die vier silberfarbenen 7,3 mm Kreuzschlitzschrauben#1, mit denen die grüne Leiterplatte am Motorgehäuse befestigt ist.
I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
Oula Kuuva - 답글
Löse die drei Plastikstecker an der linken Seite der Leiterplatte.
Löse die beiden Plastikstecker oben an der Leiterplatte.
Löse die drei Plastikstecker rechts an der Leiterplatte.
Some of the connectors have locks on them, I would recommend this as a two person job.
I didn't take them off :)
I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
Nachdem du die vorbereitenden Schritte ausgeführt hast, drehe dein Lenkrad auf den Kopf.
Löse die vier etwas oberhalb der Mittellinie befindlichen Schrauben vom Boden des Geräts mit einem Kreuzschraubendreher PH1.
Drehe das Lenkrad wieder in die ursprüngliche Position und entferne das Motorgehäuse vom Rest des Geräts.
Ziehe den 5-poligen Stecker von der Rückseite des optischen Encoders.
Entferne das Schutzgehäuse, indem du es mit einem Schlitzschraubendreher oder Hebelwerkzeug öffnest.
bonsoir ou acheter les conecteur blanc avec les 5 fils pour volant g27
ou acheter les connecteur blanc avec les 5 fils de couleur du volant g27
Löse die beiden silbernen Schrauben von der Unterseite des optischen Encoders mit einem PH0 Kreuzschlitzschraubendreher. Das wird die Platine vom Motor lösen und die neue kann eingesetzt werden.
my wheel wont calibrate and sometimes it spits out a “power surge on usb” error and my optical encoder is good, what do i do?
I like this replacement. https://es.aliexpress.com/item/329959435...
At first I didn't calibrate myself. I realised that it has to be fully inserted and satin with the end of the motorbike cylinder, as you can see in the seller's pictures. Then it did calibrate.
Stelle während dem Zusammenbau sicher, dass der Anschlag auf dem Zahnrad mit der Zahnstange ausgerichtet ist wie auf dem zweiten und dritten Bild.
Gehe auch sicher, dass der metallene halbkreisförmige Clip wieder ordentlich in der dazugehörigen Aufnahme sitzt.
Nachdem du den metallenen Clip wieder in die Aufnahme gesteckt hast, setze das Zahnrad wieder auf den Clip und auf die Zahnstange.
Befolge die Anleitung in umgekehrter Reihenfolge, um das Gerät wieder zusammenzubauen.
다른 45명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 28개
Hello and thanks for the guide. I understand this might be off topic, but would you happen to know the pinout of the7-pin connector in step 5? There is no label on the pins. Thanks in advance for your time.
Are you sure about Step 19 alignment. Some other guy with G25 says it has to be dead centre alligned otherwise you get blinking lights.And that's exactly what happens to me.
hi! i reassembled mine positioning it all the way to the right, and i have blinking power light and my wheel do not calibrate. what do you mean by dead centre aligned? i have to assemble it back together in center position, is that it?
Hey, really big thanks for this guide! I opened my wheel and found the optical encoder broken as foreseen. Just bought the brass version, but for the first instance I fixed the encoder by wrapping some thin tape around the edges and cut off the rest. worked well, but is not meant for a long time use.
As I managed to make this fault, please add a hint that when rearranging the wheel (reverse step 1+2 the thin wheel button wires love to slip close to the bottom left and right screwholes with the risk to be squezzed between wheel and wheel hub. Now I have repaired the wheel function and wrecked the upper left button function :-)
You can buy a printed version here: https://www.shapeways.com/product/4FDSWS...
It worked great for me, it shipped within a week and I'm using it now for over 2 years without any problems.
2 versions are sold: 30 and 60 slot encoder.
60 slot is for G25 and early G27 later G27 wheels use the 30 slot version.
The three hub screws in step 6 refused to go all the way back in, and one of them stripped completely. If this happens to you, you can get shorter screws here to replace those very long screws - https://www.amazon.com/gp/product/B01MFA...
Also the best replacement in terms of longevity for the encoder disk is the brass ones that you can order here, but shipping takes quite a while - http://cmlaserservice.com/index.html
I tried to 3D print one myself but it didn't work.
can you please share me the motor specifications?
Gokulraj S - 답글
Is this questin for me?
yeah ! I need this motor specifications :)
Repaired with this guide, thanks.
For the repair of the optical encoder I used a washer.
not encoder?? Washer??
is it work sameway??
I user a washer to repair the broken optical encoder.
smigolxp -
Excellent guide and thanks for the publication and your help !!!
Luca Ragno - 답글
!!!!Took me a white 2FIX it but!!! LISTEN! !!If Your wheel aiant straight in center with good or new encoder TRY first in windows controllers menu .Wherę IT shows controler. Devices while pointing at your g25,7dfgt Device :Press Ctr+shift and right Mouse to engage wheel calibration. Thank you and You Welcome ;)
Hi everyone. You can buy a replacement from there. Optical encoders available with 30 or 60 Slot. For 30 Slot check out this https://www.ebay.com/itm/264059488231 and for 60 Slot check out this https://www.ebay.com/itm/264059495927
Where can I order the optical IR sensor? I’m not getting my drive on without one …
If someone tries do do this: Do not do step 9 to 16. It’s completely unnecessary and will just make it harder to assemble again. You can remove the cable and casing as described in step 17 just fine with some fiddling.
If you disassemble it completely as shown in this guide you will have to align the stop gear to the track again (step 19), which just doesn’t work well by visual estimate alone.
Hello
I changed my optical wheel, but after that my g27 doesn’t calibrate : power led is blinking, but the wheel doesn’t make its calibration process as the wheel is not moving… After three attempts, power led is blinking fast and that’s all.
I made a video of this problem : https://youtu.be/hihREK_QC1Q
I thought my optical wheel was too low (or too high) on the engin axis, so I tried to change its position but no effect.
If you have any idea…
Sylvain Jn - 답글
I had the same issue. If you have a 3d-printed optical wheel replacement make sure to completely cover it with black marker. It has to be all the way black otherwise light can shine through the spokes and the encoder sends an error which results in the issue you’re having.
So even if it looks black.. just try again with the black marker..
Don H -
how many slot encoder do i need?
Good day sir
I have lost the 5 pin adapter
Please help me i am unable to find 5-pin adapter for encoder part online
I want to purchase it
