주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G27 Pedal Spring Replacement
필요한 것
  1. Logitech G27 Pedal Spring Replacement, Pedal Spring: 1 단계, 이미지 1개 중 1개
    • Remove two screws from each pedal with a 2.5mm allen wrench.
    • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
    • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
  2. Logitech G27 Pedal Spring Replacement: 2 단계, 이미지 2개 중 1개 Logitech G27 Pedal Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
    • There are two of these screws under the carpet grip, make sure you don't miss those!
    • When finished, flip over the device again so that it's in its original position.
  3. Logitech G27 Pedal Spring Replacement: 3 단계, 이미지 3개 중 1개 Logitech G27 Pedal Spring Replacement: 3 단계, 이미지 3개 중 2개 Logitech G27 Pedal Spring Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
    • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
    • Once the wires are no longer connected to the top cover, remove the cover completely.
  4. Logitech G27 Pedal Spring Replacement: 4 단계, 이미지 2개 중 1개 Logitech G27 Pedal Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
    • This will take two 2.5mm allen wrenches, one for each side of the screw.
    • Once removed, the piston can rotate free of the pedal.
  5. Logitech G27 Pedal Spring Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
    • Take out the spring, and replace it with a new one.
    • Repeat steps four and five for each pedal that needs a spring replaced.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Grant Blake
회원 가입일: 04/21/15
1,782 평판
안내서 2개를 작성함
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G4
4 회원들
안내서 25개를 작성함
6가이드 댓글
Is it possible to replace / renew the potentiometers used for gas / brake?
Dave Pawson - 답글 공유
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - 답글 공유
What size is the cluch spring
isaacjohnson138 - 답글 공유
6cm length
2cm diameter
hermimaier - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 182
전체 시간: 22,995
