주요 콘텐츠로 건너뛰기
Logitech G29 Driving Force Buttons Replacement
필요한 것
  1. Logitech G29 Driving Force Buttons Replacement, Buttons: 1 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Buttons Replacement, Buttons: 1 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Buttons Replacement, Buttons: 1 단계, 이미지 3개 중 3개
    • Remove the six black screws holding the Playstation center cap using the Hex 4.0 bit.
    • The outer diameter of these screws are 8.40mm with a length of 26mm.
    • The wheel is still attached the base via a bundled cable-connector.
  2. Logitech G29 Driving Force Buttons Replacement: 2 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Buttons Replacement: 2 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Gently lift the faceplate and wheel off the stand.
    • Pull the white 7-pin cable connector from the wheel PCB.
    • Use a spudger or plastic opening tool to help free the connector at its base. Do not pull on the wires.
  3. Logitech G29 Driving Force Buttons Replacement: 3 단계, 이미지 2개 중 1개 Logitech G29 Driving Force Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the seven 8 mm silver screws that secure the main wheel PCB.
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw from the Share/Options/PlayStation button PCB.
  4. Logitech G29 Driving Force Buttons Replacement: 4 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Buttons Replacement: 4 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Buttons Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Once the PCB is out, the triangle, square, circle, x button will be exposed. Use the angled tweezers to remove all four buttons.
    • These buttons are keyed to where only a certain key will fit in a certain spot.
  5. Logitech G29 Driving Force Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Once the PCB is out, the D-PAD will fall out as well. Use the angled tweezers to remove the D-PAD.
    • This is also keyed to where it can only fit in a certain direction.
  6. Logitech G29 Driving Force Buttons Replacement: 6 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Buttons Replacement: 6 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the four black 5 mm screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons.
    • The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
  7. Logitech G29 Driving Force Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four black screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons. The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
결론
작성자
6다른 기여자 명과 함께
Ben varner
회원 가입일: 11/08/23
400 평판
안내서 3개를 작성함
IUPUI, Team 1-3, Harley Fall 2023 IUPUI, Team 1-3, Harley Fall 2023 회원
IUPUI-HARLEY-F23S1G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 48
지난 30일: 204
전체 시간: 3,516
