주요 콘텐츠로 건너뛰기
Logitech G29 Driving Force Force-Feedback Motor Replacement
필요한 것
  1. Logitech G29 Driving Force Force-Feedback Motor Replacement, Force-Feedback Motor: 1 단계, 이미지 1/1
    • Remove the six 32mm long 4mm allen screws from the faceplate of the steering wheel
  2. Logitech G29 Driving Force Force-Feedback Motor Replacement: 2 단계, 이미지 1/1
    • Now, Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Force-Feedback Motor Replacement: 3 단계, 이미지 1/1
    • Carefully unplug the wire connector from the motherboard of the steering wheel
  4. Logitech G29 Driving Force Force-Feedback Motor Replacement: 4 단계, 이미지 1/2 Logitech G29 Driving Force Force-Feedback Motor Replacement: 4 단계, 이미지 2/2
    • Using the #1 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
  5. Logitech G29 Driving Force Force-Feedback Motor Replacement: 5 단계, 이미지 1/1
    • Remove the 15.9mm long silver screws on the bottom of the base of the wheel with a Phillips #1 screwdriver.
  6. Logitech G29 Driving Force Force-Feedback Motor Replacement: 6 단계, 이미지 1/1
    • Now remove the four 7.3mm long silver screws from the motherboard using a Phillips #2 screwdriver.
    • Then, carefully remove the seven plastic connectors from the motherboard. Make sure to avoid pulling by the wires and to only pull on the plastic
  7. Logitech G29 Driving Force Force-Feedback Motor Replacement: 7 단계, 이미지 1/1
    • Remove the two black screws using a Phillips #2 screwdriver.
  8. Logitech G29 Driving Force Force-Feedback Motor Replacement: 8 단계, 이미지 1/1
    • Remove the four 12mm long screws with the phillips #1 screwdriver
  9. Logitech G29 Driving Force Force-Feedback Motor Replacement: 9 단계, 이미지 1/1
    • Now that the complete driving assembly is out you can replace it as needed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Isaac Seagle
회원 가입일: 09/16/22
391 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-5, Virtue Fall 2022 Western Carolina University, Team 1-5, Virtue Fall 2022 회원
WCU-VIRTUE-F22S1G5
4 회원들
안내서 11개 작성하였습니다
댓글 3개
how much is this part
glenn castillo - 답글
where do u get repayment parts ?
callum smith - 답글
Where can we find some replacments parts ?
super miaoumix - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 75
30일 전: 364
전체 시간: 8,480
