주요 콘텐츠로 건너뛰기
Logitech G29 Driving Force Red Dial Replacement
필요한 것
  1. Logitech G29 Driving Force Red Dial Replacement, Red Dial: 1 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Red Dial Replacement, Red Dial: 1 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Red Dial Replacement, Red Dial: 1 단계, 이미지 3개 중 3개
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Red Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Remove wire connecting the PCB to the base of the wheel.
  3. Logitech G29 Driving Force Red Dial Replacement: 3 단계, 이미지 2개 중 1개 Logitech G29 Driving Force Red Dial Replacement: 3 단계, 이미지 2개 중 2개
    • Take off the 7 (4.32mm diameter 8mm long) silver screws holding the PCB to the black housing on the wheel using bit Ph #0.
    • Move the PCB to the side to expose the back side of the red dial. Keep the remaining white cable connected to the secondary PCB.
    • Be careful not to lose the buttons and D-pad; once the PCB is removed they can easily be lost.
  4. Logitech G29 Driving Force Red Dial Replacement: 4 단계, 이미지 2개 중 1개 Logitech G29 Driving Force Red Dial Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, push the black center button out to reveal 3 small black screws.
    • Using the same bit as earlier (bit Ph #00), remove the three (3.32mm diameter 5mm length) screws to release the red dial.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ben varner
회원 가입일: 11/08/23
400 평판
안내서 3개를 작성함
IUPUI, Team 1-3, Harley Fall 2023 IUPUI, Team 1-3, Harley Fall 2023 회원
IUPUI-HARLEY-F23S1G3
4 회원들
안내서 3개를 작성함
1가이드 댓글
Where can the part be bought?
Jesu de Gannes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 64
전체 시간: 2,352
