주요 콘텐츠로 건너뛰기
Logitech G29 Driving Force Share/Options/PS Buttons Replacement
필요한 것
  1. Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 1 단계, 이미지 3개 중 1개 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 1 단계, 이미지 3개 중 2개 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 1 단계, 이미지 3개 중 3개
    • Remove the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. These screws have an outer diameter of 8.40mm with a length of 26mm.
    • Once the center cap is removed, detach the face of the wheel from the stand. Before removing it completely, disconnect the 7 pin white cable running into the base of the wheel, and place aside.
  2. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit J0.
  3. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Remove Daughterboard using bit J0
    • Remove the 2 small black screws diameter 3.41mmlength 5mm from the small PCB using the J00 bit. Once the small PCB is unscrewed set the whole board aside. This will expose a black housing that all three buttons are attached to. This was removed using the same bit and screws of the same diameter.
  4. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • A black housing that all three buttons are attached to will be seen. This was removed using the same bit and screws of the same diameter.
  5. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Pick up black housing using fingers (universal size) and remove.
결론
작성자
5다른 기여자 명과 함께
Ben varner
회원 가입일: 11/08/23
400 평판
안내서 3개를 작성함
IUPUI, Team 1-3, Harley Fall 2023 IUPUI, Team 1-3, Harley Fall 2023 회원
IUPUI-HARLEY-F23S1G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 48
전체 시간: 1,053
