주요 콘텐츠로 건너뛰기
Logitech G305 Scroll Wheel Replacement
필요한 것
  1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 1개 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
  2. Logitech G305 Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four bottom case screws.
    • Caution, do not strip the head of the screws. These are not easily replaceable.
  3. Logitech G305 Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
    • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
    • Use caution when raising the outer shell—wires are still connected inside.
  4. Logitech G305 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech G305 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
  5. Logitech G305 Scroll Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
  6. Logitech G305 Scroll Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips screw driver #00 to remove the four screws.
    • Be careful to not strip the screws, these can't be found at your local hardware store.
  7. Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 1개 Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 2개 Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 3개
    • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
    • Remove the motherboard out of the casing.
    • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Rosales
회원 가입일: 02/21/22
385 평판
안내서 1개를 작성함
1가이드 댓글
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 81
지난 30일: 416
전체 시간: 25,816
