주요 콘텐츠로 건너뛰기
Logitech G400s Mouse Cable Replacement
필요한 것
  1. Logitech G400s Mouse Cable Replacement, Mouse Cable: 1 단계, 이미지 1/1
    • Use a Jimmy to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Mouse Cable Replacement: 2 단계, 이미지 1/1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Mouse Cable Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Mouse Cable Replacement: 4 단계, 이미지 1/1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Mouse Cable Replacement: 5 단계, 이미지 1/1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Mouse Cable Replacement: 6 단계, 이미지 1/2 Logitech G400s Mouse Cable Replacement: 6 단계, 이미지 2/2
    • Push the cable into its proper place inside the mouse shell.
결론
Max Evans
회원 가입일: 09/28/16
403 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-7, Eyestone Fall 2016 USF Tampa, Team 16-7, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G7
1 회원
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 47
전체 시간: 4,276
