주요 콘텐츠로 건너뛰기
Logitech G400s Scroll Wheel Replacement
필요한 것
  1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 1/1
    • Use a flathead screwdriver or your fingernail to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Scroll Wheel Replacement: 2 단계, 이미지 1/1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Scroll Wheel Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Scroll Wheel Replacement: 4 단계, 이미지 1/1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Scroll Wheel Replacement: 5 단계, 이미지 1/1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Scroll Wheel Replacement: 6 단계, 이미지 1/1
    • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Max Evans
회원 가입일: 09/28/16
403 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-7, Eyestone Fall 2016 USF Tampa, Team 16-7, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G7
1 회원
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 43
전체 시간: 3,685
