소개
If the ear cushions on your Logitech G432 are worn, torn, or nonfunctional for any reason, you most likely require replacements.
A functional ear cushion provides comfort for your ears during long periods of headset usage. Eventually, ear cushions become overworn, which might cause them to feel considerably less comfortable or even uncomfortable on your ears. Sometimes outside factors can cause this discomfort as well, such as a tear in the cushion from something sharp. If you notice that your ear cushions are beginning to feel uncomfortable, first check to see if there is any visible damage. If there is not, the cushions are most likely just worn out from long periods of usage. Regardless of the cause, your ear cushions will require replacement either way.
Check for visible damage to see which cushions need to be replaced.
필요한 것
댓글 한 개
Qué almohadillas de prestaciones y calidad similares a las originales recomiendan para su reparación? Solo encuentro recambios de terceros pero no unas oficiales suministrados por Logitech que garanticen ser iguales a las que utilizan en la etapa de fabricación. Gracias
