주요 콘텐츠로 건너뛰기
Logitech G533 Headphones doesnt work without USB cable
필요한 것
    • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
    • If your headphones still have a warranty, just return them to the shop.
    • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
  1. Logitech G533 Headphones  doesnt work without USB cable: 4 단계, 이미지 1개 중 1개
    • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
  2. Logitech G533 Headphones  doesnt work without USB cable: 5 단계, 이미지 1개 중 1개
    • Unscrew 4 screws with Torx Security TR8 bit.
  3. Logitech G533 Headphones  doesnt work without USB cable: 6 단계, 이미지 1개 중 1개
    • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
    • Unscrew the 5 screws marked on the picture with Philips 0 bit.
  4. Logitech G533 Headphones  doesnt work without USB cable: 7 단계, 이미지 1개 중 1개
    • Loosen the screw on the picture and slide up the black top under it.
  5. Logitech G533 Headphones  doesnt work without USB cable: 8 단계, 이미지 1개 중 1개
    • Take out the middle frame piece.
    • You will need to push the speaker through the frame and take out the mic off the frame.
  6. Logitech G533 Headphones  doesnt work without USB cable: 9 단계, 이미지 1개 중 1개
    • Here you can see that the red power cable is loosened.
  7. Logitech G533 Headphones  doesnt work without USB cable: 10 단계, 이미지 1개 중 1개
    • It looks like the cables are not soldered to the printed circuit. Just glued to it.
    • Scrap off the glue. I used a scalpel.
  8. Logitech G533 Headphones  doesnt work without USB cable: 11 단계, 이미지 1개 중 1개
    • You can plug back the battery and hold the cable in its original place.
    • Switch the power button and the power light should turn on.
    • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
  9. Logitech G533 Headphones  doesnt work without USB cable: 12 단계, 이미지 1개 중 1개
    • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
    • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
  10. Logitech G533 Headphones  doesnt work without USB cable: 13 단계, 이미지 1개 중 1개
    • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
    • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kobda
회원 가입일: 01/14/21
437 평판
안내서 1개를 작성함
9가이드 댓글
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - 답글
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda -
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel -
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Kobda -
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 105
전체 시간: 7,472
