주요 콘텐츠로 건너뛰기
Logitech G602 Scroll Wheel Replacement
필요한 것
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: 1 단계, 이미지 1/1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: 3 단계, 이미지 1/2 Logitech G602 Scroll Wheel Replacement: 3 단계, 이미지 2/2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: 4 단계, 이미지 1/1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
    No idea what this is supposed to mean. The name of this guide is "replacement". The final instruction here is to "test the wheel's usability"?
    Felix - 답글
결론
다른 8명이 해당 안내서를 완성하였습니다.
Jerico Morales
회원 가입일: 01/17/18
1,219 평판
안내서 4개 작성하였습니다
댓글 2개
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - 답글
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 82
전체 시간: 7,963
