주요 콘텐츠로 건너뛰기
Logitech G602 Side Motherboard Replacement
필요한 것
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: 1 단계, 이미지 1개 중 1개
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Logitech G602 Side Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Logitech G602 Side Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matthew Ross
회원 가입일: 01/17/18
193 평판
안내서 1개를 작성함
2가이드 댓글
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - 답글
G5 Button was sticking. Followed guide, I did not need spudger. Brushed board and buttons with toothbrush and alcohol. Button works now, thanks!
P Kemp - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 53
전체 시간: 4,687
