주요 콘텐츠로 건너뛰기
Logitech G700s Left and Right Mouse Button Disassembly
필요한 것
  1. Logitech G700s Left and Right Mouse Button Disassembly, Top Case Replacement: 1 단계, 이미지 1개 중 1개
    • Remove the batteries from the mouse.
    • Use a plastic opening tool to peel up the four mouse feet.
  2. Logitech G700s Left and Right Mouse Button Disassembly: 2 단계, 이미지 2개 중 1개 Logitech G700s Left and Right Mouse Button Disassembly: 2 단계, 이미지 2개 중 2개
    • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
  3. Logitech G700s Left and Right Mouse Button Disassembly: 3 단계, 이미지 3개 중 1개 Logitech G700s Left and Right Mouse Button Disassembly: 3 단계, 이미지 3개 중 2개 Logitech G700s Left and Right Mouse Button Disassembly: 3 단계, 이미지 3개 중 3개
    • Pull the top of the mouse off of the bottom half.
    • There's a wire connecting the two halves.
    • Unplug the programmable buttons from the motherboard.
    • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
  4. Logitech G700s Left and Right Mouse Button Disassembly, Logitech G700s Left and Right Mouse Button Disassembly: 4 단계, 이미지 2개 중 1개 Logitech G700s Left and Right Mouse Button Disassembly, Logitech G700s Left and Right Mouse Button Disassembly: 4 단계, 이미지 2개 중 2개
    • Pop the right button piston off the ledge thingy
    • Then pop the left button piston off
    • It can take a bit of force to pop them off.
  5. Logitech G700s Left and Right Mouse Button Disassembly: 5 단계, 이미지 2개 중 1개 Logitech G700s Left and Right Mouse Button Disassembly: 5 단계, 이미지 2개 중 2개
    • Remove the three Philips head screws holding the left and right button clicker in place
  6. Logitech G700s Left and Right Mouse Button Disassembly: 6 단계, 이미지 2개 중 1개 Logitech G700s Left and Right Mouse Button Disassembly: 6 단계, 이미지 2개 중 2개
    • Remove the left and right button & G13 & scroll wheel lock assembly from the top shell assembly.
    • You can push on indicated locations to gain leverage
결론
작성자
1다른 기여자 명과 함께
dennis97519
회원 가입일: 10/18/11
507 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 39
전체 시간: 2,543
