주요 콘텐츠로 건너뛰기
Logitech G710+ Disassembly
필요한 것
  1. Logitech G710+ Disassembly, Body: 1 단계, 이미지 1개 중 1개
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
  2. Logitech G710+ Disassembly, Mother board: 2 단계, 이미지 3개 중 1개 Logitech G710+ Disassembly, Mother board: 2 단계, 이미지 3개 중 2개 Logitech G710+ Disassembly, Mother board: 2 단계, 이미지 3개 중 3개
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
  3. Logitech G710+ Disassembly, Scroll Wheel: 3 단계, 이미지 1개 중 1개
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
  4. Logitech G710+ Disassembly, Pads: 4 단계, 이미지 1개 중 1개
    • You can then take off the little pads
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jackson Poer
회원 가입일: 04/08/17
683 평판
안내서 2개를 작성함
3가이드 댓글
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - 답글
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - 답글
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 76
전체 시간: 9,222
