이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Unscrew the one screw holding on the ground and pull out the cables.
A good way of getting the cables out is by putting a screwdriver right there and twisting.
Unscrew this screw
The light thing comes out with a wiggle.
The scroll wheel on the other is harder because you have to melt or brake the supports off.
Then you have to get the wheel out which comes out with a very gentle wiggle.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
