주요 콘텐츠로 건너뛰기
Logitech G733 Volume Scroll Wheel Replacement
필요한 것
  1. Logitech G733 Volume Scroll Wheel Replacement, Volume Scroll Wheel: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
  2. Logitech G733 Volume Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Logitech G733 Volume Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four screws securing the speaker housing using the T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
  3. Logitech G733 Volume Scroll Wheel Replacement: 3 단계, 이미지 3개 중 1개 Logitech G733 Volume Scroll Wheel Replacement: 3 단계, 이미지 3개 중 2개 Logitech G733 Volume Scroll Wheel Replacement: 3 단계, 이미지 3개 중 3개
    • The plastic cover should be lose now and you should be able to pull it back to reveal the circuit board inside.
    • Unscrew the screw on the bottom right-hand side of the headphone using the #000 Phillips Screwdriver.
    • Finally, use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
    • The scroll wheel may fly out when you pop the circuit board out.
  4. Logitech G733 Volume Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech G733 Volume Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the volume wheel directly out.
    • Place the new scroll wheel in by lining up the two flat surfaces on the connectors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Antonio Jensen
회원 가입일: 02/14/23
727 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 128
전체 시간: 4,467
