주요 콘텐츠로 건너뛰기
Logitech G910 Lights Replacement
필요한 것
  1. Logitech G910 Lights Replacement, Lights: 1 단계, 이미지 1/1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: 2 단계, 이미지 1/1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: 3 단계, 이미지 1/1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: 4 단계, 이미지 1/2 Logitech G910 Lights Replacement, Lift the film: 4 단계, 이미지 2/2
    • Gently lift up the plastic film in the top right corner.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Nasser
회원 가입일: 01/23/18
214 평판
안내서 1개 작성함
댓글 3개
So what do I do after I take apart my keyboard?
CuddlyZebesian - 답글
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 28
30일 전: 108
전체 시간: 6,104
