소개
This guide will teach you how to replace the power cord of your device. It's a relatively easy process, and you won't be needing any special skills.
필요한 것
Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Hello,
Where can I find a replacement USB cord ?
My board works fine but sometimes disconnects before the power cable is really used. I just want to change that cable
Yeah there is not problem replacing it but to find the cord itself. Cant seems to find replacement on the web.
