주요 콘텐츠로 건너뛰기
Logitech G910 Power Cord Replacement
필요한 것
  1. Logitech G910 Power Cord Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
  2. Logitech G910 Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the USB from the keyboard.
  3. Logitech G910 Power Cord Replacement: 3 단계, 이미지 1개 중 1개
    • Make sure the cord tab is not broken.
  4. Logitech G910 Power Cord Replacement: 4 단계, 이미지 1개 중 1개
    • If the cord tab is not broken, close it back.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ahmed Al Hasan
회원 가입일: 01/18/18
145 평판
안내서 1개를 작성함
3가이드 댓글
Hello,
Where can I find a replacement USB cord ?
My board works fine but sometimes disconnects before the power cable is really used. I just want to change that cable
pittetflavia - 답글
Yeah there is not problem replacing it but to find the cord itself. Cant seems to find replacement on the web.
LordGrizwold - 답글
So far every guide for the G910 feels incomplete. SMH. New people, don't feel it's you if they look like steps are missing.
Wesley Mason - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 47
전체 시간: 6,359
