소개
Use this guide to remove and replace the volume wheel on the Logitech G915 TKL keyboard. The volume wheel may need to be replaced if it's come loose due it breaking and is no longer working properly.
A Phillips #00 Screwdriver is necessary to complete this guide.
필요한 것
Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
Remove the backplate by grabbing the notch to the right and pulling up.
다른 한 분이 해당 안내서를 완성하였습니다.
