주요 콘텐츠로 건너뛰기
Logitech G920 Driving Force Back Pedals Replacement
필요한 것
  1. Logitech G920 Driving Force Back Pedals Replacement, Back Pedals: 1 단계, 이미지 1개 중 1개
    • Locate the pedal you need to replace.
  2. Logitech G920 Driving Force Back Pedals Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Hex 2.5 screwdriver or Allen key to remove the two 30 mm center screws in the pedal.
  3. Logitech G920 Driving Force Back Pedals Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the pedals from their stand.
    • Repeat steps 2-3 until all pedals needing replacement are removed.
  4. Logitech G920 Driving Force Back Pedals Replacement: 4 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Back Pedals Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 12 12mm screws from the bottom of the device using a Phillips #1 screwdriver.
  5. Logitech G920 Driving Force Back Pedals Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the eight 12 mm screws from the bottom of the device with a Phillips #0 screwdriver.
  6. Logitech G920 Driving Force Back Pedals Replacement: 6 단계, 이미지 3개 중 1개 Logitech G920 Driving Force Back Pedals Replacement: 6 단계, 이미지 3개 중 2개 Logitech G920 Driving Force Back Pedals Replacement: 6 단계, 이미지 3개 중 3개
    • Push down the switch found in the hole at the top of the underside of the pedal board.
    • This opens the carpet-hold to access more screws.
  7. Logitech G920 Driving Force Back Pedals Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 14 mm screws behind the carpet hold with a Phillips #0 screwdriver.
  8. Logitech G920 Driving Force Back Pedals Replacement: 8 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Back Pedals Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the pedal back that matches the pedal front removed in step 3 .
    • This image is not upside down. When removing the back panel piece, the lettering on the inner pedal mechanism will appear this way.
  9. Logitech G920 Driving Force Back Pedals Replacement: 9 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Back Pedals Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the washer and bolt at the top of the red piece on the pedal back.
  10. Logitech G920 Driving Force Back Pedals Replacement: 10 단계, 이미지 3개 중 1개 Logitech G920 Driving Force Back Pedals Replacement: 10 단계, 이미지 3개 중 2개 Logitech G920 Driving Force Back Pedals Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the red piece, spring, and block within the pedal back.
    • Replace the necessary part.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Aiden Muse
회원 가입일: 09/12/23
594 평판
안내서 3개를 작성함
1가이드 댓글
My set of pedals has an issue of continuously press break pedal, any idea what it can be? When I lift them into vertical position (holl base) it stops, but the again as horizontal (ready to be use) in the games like Forza EuroTruck Assets... etc, system behave as break pedal is press.
Olaf Tomczynski - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 34
지난 30일: 170
전체 시간: 2,240
