주요 콘텐츠로 건너뛰기
Logitech G920 Driving Force Motor Motherboard Replacement
필요한 것
  1. Logitech G920 Driving Force Motor Motherboard Replacement, Motor Motherboard: 1 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force Motor Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force Motor Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force Motor Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force Motor Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 13.5 mm screws with a Phillips #0 screwdriver.
  6. Logitech G920 Driving Force Motor Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the pedals from both sides of the wheel base.
  7. Logitech G920 Driving Force Motor Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three 36 mm screws with a Phillips #2 screwdriver.
  8. Logitech G920 Driving Force Motor Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Logitech G920 Driving Force Motor Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the wheel base from the motor box.
  9. Logitech G920 Driving Force Motor Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the motor box over.
    • Remove the twelve 12.2 mm screws with a Phillips #0 screwdriver.
    • Remove the two 11.5 mm screws with a Phillips #0 screwdriver.
  10. Logitech G920 Driving Force Motor Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Flip over the motor box once more.
    • Remove the motor box cover.
  11. Logitech G920 Driving Force Motor Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Logitech G920 Driving Force Motor Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Logitech G920 Driving Force Motor Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the four 5 mm screws with a Phillips #0 screwdriver.
    • Detach the wires connected to the motherboard.
    • Remove the motherboard from the motor box.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Aiden Muse
회원 가입일: 09/12/23
594 평판
안내서 3개를 작성함
1가이드 댓글
Which wire is for the USB?
Davoyles lags - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 69
지난 30일: 235
전체 시간: 5,733
