주요 콘텐츠로 건너뛰기
Logitech Gamepad F310 Case Replacement
필요한 것
  1. Logitech Gamepad F310 Case Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Case Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 Case Replacement: 2 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Case Replacement: 2 단계, 이미지 2개 중 2개
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 Case Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
  4. Logitech Gamepad F310 Case Replacement, Case: 4 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Case Replacement, Case: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the slot on top.
결론
You have successfully taken the case off of your controller! Using the new case, follow these steps in reverse order to assemble your fixed controller.
작성자
3다른 기여자 명과 함께
Alan Mendoza DracoKing
회원 가입일: 02/05/24
191 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 497
