주요 콘텐츠로 건너뛰기
Logitech Gamepad F310 D-Pad Replacement
필요한 것
  1. Logitech Gamepad F310 D-Pad Replacement, Case: 1 단계, 이미지 1/2 Logitech Gamepad F310 D-Pad Replacement, Case: 1 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 D-Pad Replacement: 2 단계, 이미지 1/2 Logitech Gamepad F310 D-Pad Replacement: 2 단계, 이미지 2/2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 D-Pad Replacement: 3 단계, 이미지 1/1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
  4. Logitech Gamepad F310 D-Pad Replacement, D-Pad: 4 단계, 이미지 1/3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: 4 단계, 이미지 2/3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: 4 단계, 이미지 3/3
    • Remove the silver 3 mm screw in the middle of the D-pad with a Phillips #1 screwdriver.
    • Remove the D-pad
    • There are 4 buttons that go in the four slots of the D-pad, a spring on one side, and the D-Pad on the other side.
결론
This is how to replace a D-Pad on a Logitech Gamepad F310. To reassemble your device, follow these instructions in reverse order.
Lucas Stovall
회원 가입일: 02/07/24
319 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 26
전체 시간: 106
