주요 콘텐츠로 건너뛰기
Logitech Gamepad F310 Joystick Cover Replacement
필요한 것
  1. Logitech Gamepad F310 Joystick Cover Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Joystick Cover Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 Joystick Cover Replacement: 2 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Joystick Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 Joystick Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
  4. Logitech Gamepad F310 Joystick Cover Replacement, Joystick Cover: 4 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Joystick Cover Replacement, Joystick Cover: 4 단계, 이미지 2개 중 2개
    • Pull the joystick covers straight up and off the modules.
결론
You're finished! To reassemble your device, follow these instructions in reverse order.
작성자
3다른 기여자 명과 함께
Graydon
회원 가입일: 02/05/24
166 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 61
전체 시간: 1,310
