주요 콘텐츠로 건너뛰기
Logitech Harmony 300 Batteries Replacement
필요한 것
  1. Logitech Harmony 300 Batteries  Replacement, Identifying the Battery Housing: 1 단계, 이미지 1/1
    • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  2. Logitech Harmony 300 Batteries  Replacement, Removing the Battery Cap: 2 단계, 이미지 1/1
    • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
    • Once the cap is loosen, simply lift the cap out to reveal the batteries.
  3. Logitech Harmony 300 Batteries  Replacement, The Batteries: 3 단계, 이미지 1/2 Logitech Harmony 300 Batteries  Replacement, The Batteries: 3 단계, 이미지 2/2
    • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andres Rodriguez
회원 가입일: 10/09/14
137 평판
안내서 1개 작성함
USF Tampa, Team 1-29, Donnelly Fall 2014 USF Tampa, Team 1-29, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G29
1 회원
안내서 1개 작성하였습니다
댓글 5개
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - 답글
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - 답글
it’s impossible !!!
Pascal jade - 답글
I agree with the other comments. I’ll keep trying, but so far after 10 minutes I still can’t get the cover to budge.
Barry Boehm - 답글
pefI too found the battery cover impossible to remove “by hand”. I used the clear plastic package as a cradle for the device,
then used a flat-blade screwdriver applied to the indent where you are meant to push by hand, and pushed hard at about
about a 45° angle. Finally got it open! I filed off a bit of the hook on the cover latch so hopfully it will be easier next time.
Dave Davy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 20
전체 시간: 2,259
