주요 콘텐츠로 건너뛰기
Logitech Harmony 900 Motherboard Replacement
필요한 것
  1. Logitech Harmony 900 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Motherboard Replacement: 2 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 2 단계, 이미지 2/2
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Motherboard Replacement: 4 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 4 단계, 이미지 2/2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Motherboard Replacement: 6 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 6 단계, 이미지 2/2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Motherboard Replacement: 7 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 7 단계, 이미지 2/2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Motherboard Replacement: 8 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 8 단계, 이미지 2/2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Motherboard Replacement: 9 단계, 이미지 1/2 Logitech Harmony 900 Motherboard Replacement: 9 단계, 이미지 2/2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Motherboard Replacement: 10 단계, 이미지 1/1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
결론
To reassemble, follow the steps in reverse order.
John Adams
회원 가입일: 09/25/17
116 평판
안내서 1개 작성함
USF Tampa, Team S4-G5, Eyestone Fall 2017 USF Tampa, Team S4-G5, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 561
