주요 콘텐츠로 건너뛰기
Logitech Harmony 950 Case Replacement
필요한 것
  1. Logitech Harmony 950 Case Replacement, Battery: 1 단계, 이미지 2개 중 1개 Logitech Harmony 950 Case Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Case Replacement: 2 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 2 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Case Replacement: 3 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 3 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Case Replacement: 4 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 4 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 4 단계, 이미지 3개 중 3개
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Case Replacement, Case: 5 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement, Case: 5 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement, Case: 5 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Case Replacement: 6 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 6 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Case Replacement: 7 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 7 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 7 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws. Keep in mind that once the screws are off, the circuit board will be completely separate from the case.
    • Be careful not to damage or disconnect the pink wires when removing the gold charging conductors from the case.
  8. Logitech Harmony 950 Case Replacement: 8 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 8 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the black tape to fully access the cable underneath.
    • This cable has a locking mechanism. Use the Angled Tweezers to lift the black part (lock).
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Case Replacement: 9 단계, 이미지 2개 중 1개 Logitech Harmony 950 Case Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the circuit board off of the case. Start from the bottom, and lift up to completely detach it from the cover.
  10. Logitech Harmony 950 Case Replacement: 10 단계, 이미지 3개 중 1개 Logitech Harmony 950 Case Replacement: 10 단계, 이미지 3개 중 2개 Logitech Harmony 950 Case Replacement: 10 단계, 이미지 3개 중 3개
    • Use the Blunt Tweezers to carefully remove the keypad from the cover of the remote.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Shiba Kandel
회원 가입일: 09/26/17
149 평판
안내서 1개를 작성함
USF Tampa, Team S2-G2, Passmore Fall 2017 USF Tampa, Team S2-G2, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G2
4 회원들
안내서 7개를 작성함
4가이드 댓글
where can this casing be purchased?
Sharonda Bailey - 답글
Parts are required obviously!!
larrybud2004 - 답글
Is the usb bottom cap part of the replacement case? If not can u get one?
jmorrissette - 답글
Hello,
short question: does someone know, if and where you can get a replacement case for Harmony 950 remote control?
Thx in advance
D. Schick - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 88
전체 시간: 4,776
