주요 콘텐츠로 건너뛰기
Logitech Harmony 950 Motherboard Replacement
필요한 것
  1. Logitech Harmony 950 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Logitech Harmony 950 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Motherboard Replacement: 2 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 2 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Motherboard Replacement: 3 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 3 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 3 단계, 이미지 3/3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Motherboard Replacement: 4 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 4 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Motherboard Replacement: 6 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 6 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $3.99
    구매
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Motherboard Replacement: 7 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 7 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 7 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws.
    • Be careful not to detach the pink wires when removing the gold charging conductors.
  8. Logitech Harmony 950 Motherboard Replacement: 8 단계, 이미지 1/3 Logitech Harmony 950 Motherboard Replacement: 8 단계, 이미지 2/3 Logitech Harmony 950 Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove the black tape to access the cable underneath.
    • Use the Angled Tweezers to lift the black lock.
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Motherboard Replacement: 9 단계, 이미지 1/2 Logitech Harmony 950 Motherboard Replacement: 9 단계, 이미지 2/2
    • Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Blake Sanborn
회원 가입일: 09/26/17
546 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G2, Passmore Fall 2017 USF Tampa, Team S2-G2, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G2
4 회원들
안내서 4개 작성하였습니다
댓글 3개
How replace A Mitsubishi Remote Control
عبدالعزيز المناعي - 답글
How replace A Mitsubishi Remote Control ?
Thanks
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 49
전체 시간: 2,589
