주요 콘텐츠로 건너뛰기
Logitech Harmony Companion Button Pad Replacement
필요한 것
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: 1 단계, 이미지 1개 중 1개
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Push the battery cover upward.
  3. Logitech Harmony Companion Button Pad Replacement: 3 단계, 이미지 3개 중 1개 Logitech Harmony Companion Button Pad Replacement: 3 단계, 이미지 3개 중 2개 Logitech Harmony Companion Button Pad Replacement: 3 단계, 이미지 3개 중 3개
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: 4 단계, 이미지 2개 중 1개 Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: 5 단계, 이미지 2개 중 1개 Logitech Harmony Companion Button Pad Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: 6 단계, 이미지 2개 중 1개 Logitech Harmony Companion Button Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the motherboard.
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: 7 단계, 이미지 3개 중 1개 Logitech Harmony Companion Button Pad Replacement, Button Pad: 7 단계, 이미지 3개 중 2개 Logitech Harmony Companion Button Pad Replacement, Button Pad: 7 단계, 이미지 3개 중 3개
    • Lift the button pad up to remove it from the remote.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cassidy Wardlow
회원 가입일: 09/28/17
716 평판
안내서 4개를 작성함
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 회원
USFT-NANCE-F17S1G3
3 회원들
안내서 4개를 작성함
4가이드 댓글
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - 답글
Where can I purchase the button pad?
elijah - 답글
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - 답글
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 3,532
