주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Control Remote Buttons Replacement
필요한 것
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: 1 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: 1 단계, 이미지 2개 중 2개
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Remote Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: 3 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Remote Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: 4 단계, 이미지 3개 중 1개 Logitech Harmony Smart Control Remote Buttons Replacement: 4 단계, 이미지 3개 중 2개 Logitech Harmony Smart Control Remote Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Josh Hendricks
회원 가입일: 09/17/15
464 평판
안내서 4개를 작성함
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G2
4 회원들
안내서 5개를 작성함
9가이드 댓글
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - 답글
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - 답글
Flavio Campos - 답글
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 31
전체 시간: 6,189
