주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement
필요한 것
  1. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: 1 단계, 이미지 1/2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: 1 단계, 이미지 2/2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 2 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 2 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 2 단계, 이미지 3/3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 3 단계, 이미지 1/1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 4 단계, 이미지 1/2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 4 단계, 이미지 2/2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 5 단계, 이미지 1/2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 5 단계, 이미지 2/2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 6 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 6 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 6 단계, 이미지 3/3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 7 단계, 이미지 1/2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 7 단계, 이미지 2/2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 8 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 8 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 8 단계, 이미지 3/3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 9 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 9 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 9 단계, 이미지 3/3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 10 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 10 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 10 단계, 이미지 3/3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 11 단계, 이미지 1/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 11 단계, 이미지 2/3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 11 단계, 이미지 3/3
    • Grip the other lower end of the ribbon flex cable using your thumb and index finger.
    • Gently slide the cable up and out of the green card.
결론
Hayley Nichols
회원 가입일: 09/05/17
525 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 회원
CSUF-BRUCE-F17S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 737
