주요 콘텐츠로 건너뛰기
Logitech Harmony Touch Motherboard Replacement
필요한 것
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Logitech Harmony Touch Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Logitech Harmony Touch Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Open the latch that covers the charging port.
    • Remove the black sticker, then remove the screw with the indicated screwdriver.
    • Take the plastic opening tool, and run it down the side of the remote to pop the case open.
    • While doing this step, there are three wires that connect the two pieces. Be sure not to rip the wires out.
    • Detach the white clamp in order to partially disconnect the case from the motherboard.
  2. Logitech Harmony Touch Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Logitech Harmony Touch Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Logitech Harmony Touch Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Peel back the thin yellow plastic film and detach the clip found underneath.
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver.
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all of the buttons and remove them from the case.
결론
작성자
7다른 기여자 명과 함께
Lennox Saliva-Rojas
회원 가입일: 09/25/17
290 평판
안내서 2개를 작성함
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 913
