주요 콘텐츠로 건너뛰기
Logitech Harmony Touch Power Adapter Replacement
필요한 것
  1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: 1 단계, 이미지 1개 중 1개
    • Open the latch that assesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screwdriver.
  2. Logitech Harmony Touch Power Adapter Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Touch Power Adapter Replacement: 2 단계, 이미지 2개 중 2개
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  3. Logitech Harmony Touch Power Adapter Replacement: 3 단계, 이미지 1개 중 1개
    • Once your device is open, check to see if wires are intact.
    • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
결론
작성자
6다른 기여자 명과 함께
Jennifer Jimenez
회원 가입일: 09/25/17
219 평판
안내서 1개를 작성함
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 12
전체 시간: 713
