주요 콘텐츠로 건너뛰기
Logitech Harmony Touch Screen Replacement
필요한 것
  1. Logitech Harmony Touch Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Logitech Harmony Touch Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Logitech Harmony Touch Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Open the latch that accesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screw driver.
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  2. Logitech Harmony Touch Screen Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Touch Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back thin yellow plastic film and detach the clip found underneath.
    • Use a Phillips #00 to remove the screws that connect the motherboard to the case.
  3. Logitech Harmony Touch Screen Replacement: 3 단계, 이미지 3개 중 1개 Logitech Harmony Touch Screen Replacement: 3 단계, 이미지 3개 중 2개 Logitech Harmony Touch Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should be able to access the screen which is located on the back of the motherboard.
  4. Logitech Harmony Touch Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the screen from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Nicholas Townsend
회원 가입일: 09/25/17
285 평판
안내서 2개를 작성함
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G2
4 회원들
안내서 5개를 작성함
2가이드 댓글
Hallo
Mit dieser Anleitung klappt das wechseln bestimmt.Ich habe nur eine frage “Woher bekomme ich ein Touchscreen für die Fernbedienung”?
Ich habe die Ultimate und bei mir ist der Touchscreen defekt.Doch ich habe noch kein Ersatz gefunden. :-( Können sie mir da weiter helfen?
belfrea - 답글
do you have the lcd screen P/N???
Alejandro Ortiz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 48
전체 시간: 5,107
