주요 콘텐츠로 건너뛰기
Logitech Harmony Ultimate Buttons Replacement
필요한 것
  1. Logitech Harmony Ultimate Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
  2. Logitech Harmony Ultimate Buttons Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
    • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
    • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
  3. Logitech Harmony Ultimate Buttons Replacement: 3 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the wires running from the back cover to the motherboard.
  4. Logitech Harmony Ultimate Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four 6mm Phillips #0 screws from the battery case.
  5. Logitech Harmony Ultimate Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
    • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
  6. Logitech Harmony Ultimate Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery and its case out of the remote.
    • The battery should still be connected to the case with adhesive.
  7. Logitech Harmony Ultimate Buttons Replacement: 7 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to separate the battery from the case.
  8. Logitech Harmony Ultimate Buttons Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Remove the four 6mm Phillips #0 screws from the motherboard.
  9. Logitech Harmony Ultimate Buttons Replacement: 9 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement: 9 단계, 이미지 2개 중 2개
    • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
    • The flap and buckle are underneath the clear yellow piece of tape.
    • Be very careful as damaging this flap could permanently damage your controller.
  10. Logitech Harmony Ultimate Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
  11. Logitech Harmony Ultimate Buttons Replacement, Buttons: 11 단계, 이미지 2개 중 1개 Logitech Harmony Ultimate Buttons Replacement, Buttons: 11 단계, 이미지 2개 중 2개
    • After successfully removing the motherboard, you can easily peel off the buttons from the controller frame.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Aaron Diaz
회원 가입일: 08/31/15
716 평판
안내서 3개를 작성함
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G1
5 회원들
안내서 9개를 작성함
2가이드 댓글
This is a great demo and it give me much more confidence to tackle the repair. I have some questions. Does the battery need to be removed as I see from your pictures, the motherboard screws are not covered by the battery - or are they? Also, where do you purchase your repair parts? Thank you!
Steve Feldner - 답글
Where do you find the parts? The Logitech website doesn’t have parts for the Ultimate
larrybud2004 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 77
전체 시간: 6,375
