주요 콘텐츠로 건너뛰기
Logitech Harmony Ultimate Charging Station Motherboard Replacement
필요한 것
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 1 단계, 이미지 1/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 1 단계, 이미지 2/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 1 단계, 이미지 3/3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 2 단계, 이미지 1/2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 3 단계, 이미지 1/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 3 단계, 이미지 2/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 4 단계, 이미지 1/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 4 단계, 이미지 2/3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
결론
Lucas Reynolds
회원 가입일: 09/01/15
333 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 24
전체 시간: 2,867
