주요 콘텐츠로 건너뛰기
Logitech K120 Keyboard Disassembly
필요한 것
동영상 개요
  1. Logitech K120 Keyboard Disassembly, Removing Screws: 1 단계, 이미지 2개 중 1개 Logitech K120 Keyboard Disassembly, Removing Screws: 1 단계, 이미지 2개 중 2개
    • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
  2. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: 2 단계, 이미지 3개 중 1개 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: 2 단계, 이미지 3개 중 2개 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: 2 단계, 이미지 3개 중 3개
    • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
  3. Logitech K120 Keyboard Disassembly, Removing The Top Of The Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the top of the keyboard and put it aside.
  4. Logitech K120 Keyboard Disassembly, Removing The Bracket: 4 단계, 이미지 3개 중 1개 Logitech K120 Keyboard Disassembly, Removing The Bracket: 4 단계, 이미지 3개 중 2개 Logitech K120 Keyboard Disassembly, Removing The Bracket: 4 단계, 이미지 3개 중 3개
    • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
  5. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: 5 단계, 이미지 3개 중 1개 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: 5 단계, 이미지 3개 중 2개 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: 5 단계, 이미지 3개 중 3개
    • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
  6. Logitech K120 Keyboard Disassembly, Removing The Cable: 6 단계, 이미지 2개 중 1개 Logitech K120 Keyboard Disassembly, Removing The Cable: 6 단계, 이미지 2개 중 2개
    • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
  7. Logitech K120 Keyboard Disassembly, Removing The Membrane: 7 단계, 이미지 2개 중 1개 Logitech K120 Keyboard Disassembly, Removing The Membrane: 7 단계, 이미지 2개 중 2개
    • Peel the membrane off carefully so that the membrane doesn't rip.
  8. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: 8 단계, 이미지 3개 중 1개 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: 8 단계, 이미지 3개 중 2개 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: 8 단계, 이미지 3개 중 3개
    • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
    • Lift the membrane off of the first standoff.
    • Peel the rest of the membrane off carefully so the membrane doesn't rip.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Camuise
회원 가입일: 11/22/18
1,603 평판
안내서 7개를 작성함
4가이드 댓글
I followed your guide for disassembly and did the opposite for reassembly, now all three leds turn on when plugged in but none of the keys respond. Any idea what I should do?
Jacob Sileski - 답글
Make sure that the rubber membrane is making contact with the pads on the plastic sheets. If they are, make sure the connector is fully plugged in. If it is, make sure the keyboard is plugged into the right USB port.
Camuise -
Haven't answered my real question does one repair or replace circuit membrane when liquid has shorted on line? Or throw out and buy a new keyboard?
KimKostyna - 답글
Your best bet is to try and clean up the membrane using isopropyl alcohol. There doesn't seem to be anywhere to buy a new circuit membrane, so if that doesn't work you'll most likely have to buy a new keyboard.
Camuise -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 126
전체 시간: 12,558
