주요 콘텐츠로 건너뛰기
Logitech M185 Wireless Mouse Disassembly
필요한 것
  1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 1 단계, 이미지 2개 중 1개 Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 1 단계, 이미지 2개 중 2개
    • Remove battery cover by sliding it off.
  2. Logitech M185 Wireless Mouse Disassembly, Unscrew: 2 단계, 이미지 2개 중 1개 Logitech M185 Wireless Mouse Disassembly, Unscrew: 2 단계, 이미지 2개 중 2개
    • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
  3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: 3 단계, 이미지 1개 중 1개
    • There is no need to remove its rubber feet since it is held together by only one screw.
    • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
    • Do not pull the grey cover towards the top and do not pull the part near the keys.
    • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
    • The image is what your mouse should look like in the end.
  4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 4 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 4 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 4 단계, 이미지 3개 중 3개
    • Push back small black clips to release the circuit board.
    • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
    • Fully remove the circuit board with the battery connectors and image sensor still attached.
  5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 5 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 5 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 5 단계, 이미지 3개 중 3개
    • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
    • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
    • Separate the two casing layers fully.
결론
다른 37명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Karmanyaah Malhotra
회원 가입일: 09/23/18
1,047 평판
안내서 1개를 작성함
12가이드 댓글
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 135
지난 30일: 714
전체 시간: 39,325
