주요 콘텐츠로 건너뛰기
Logitech M185 Wireless Mouse Scroll Wheel Replacement
필요한 것
  1. Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
    • Turn your mouse over so the bottom is facing up.
    • Slide the battery compartment door off to reveal the battery.
  2. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery.
    • Use a Phillips #00 screwdriver to remove the single screw in the battery compartment.
    • The screw may be hard to find at first, but it is directly under the battery.
  3. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 3개 중 3개
    • Place one hand on the bottom of the mouse and the other on the top. Gently remove the top of the mouse.
  4. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger and gently pry the motherboard up, to remove it from the mouse.
    • Any damage done to the board could affect the functionality of the mouse. Show EXTRA care when touching the board. Handle it along the edges only and wear ESD safe gloves if possible.
  5. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 2개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully remove the scroll wheel from the motherboard.
  6. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the new scroll wheel.
  7. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 7 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 7 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 7 단계, 이미지 3개 중 3개
    • Replace the motherboard.
    • Gently but firmly press down on it until it is securely in place.
    • You will hear a click or snap, indicating it is in place.
  8. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 8 단계, 이미지 3개 중 1개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 8 단계, 이미지 3개 중 2개 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 8 단계, 이미지 3개 중 3개
    • Put the top of the mouse back onto the bottom and press them together so they connect.
    • Make sure the edges of the top and bottom of the mouse align so there is a secure connection.
    • Use a Phillips #00 screwdriver to replace the single screw in the battery compartment.
    • Replace the battery and battery cover.
  9. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 9 단계, 이미지 1개 중 1개
    • Plug your mouse into a computer using the USB connector to ensure the scroll wheel is working.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Osame Osayande
회원 가입일: 03/05/24
190 평판
안내서 1개를 작성함
CSU Los Angeles, Team 7-7, Grodsky Spring 2024 CSU Los Angeles, Team 7-7, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G7
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 26
지난 30일: 141
전체 시간: 2,308
