주요 콘텐츠로 건너뛰기
Logitech M215 Battery Replacement
필요한 것
  1. Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Battery Replacement, Remove old battery: 2 단계, 이미지 1개 중 1개
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hannah Pate
회원 가입일: 01/30/15
1,742 평판
안내서 7개를 작성함
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S1G1
4 회원들
안내서 28개를 작성함
10가이드 댓글
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - 답글
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - 답글
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - 답글
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - 답글
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 60
지난 30일: 323
전체 시간: 122,204
