주요 콘텐츠로 건너뛰기
Logitech M215 Cover Release Button Replacement
필요한 것
  1. Logitech M215 Cover Release Button Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Logitech M215 Cover Release Button Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Logitech M215 Cover Release Button Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Cover Release Button Replacement, Remove old battery: 2 단계, 이미지 1개 중 1개
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Cover Release Button Replacement, Top Cover: 3 단계, 이미지 2개 중 1개 Logitech M215 Cover Release Button Replacement, Top Cover: 3 단계, 이미지 2개 중 2개
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Cover Release Button Replacement: 4 단계, 이미지 1개 중 1개
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Cover Release Button Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Logitech M215 Cover Release Button Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Cover Release Button Replacement, Cover Release Button: 6 단계, 이미지 3개 중 1개 Logitech M215 Cover Release Button Replacement, Cover Release Button: 6 단계, 이미지 3개 중 2개 Logitech M215 Cover Release Button Replacement, Cover Release Button: 6 단계, 이미지 3개 중 3개
    • Unscrew the 0.25mm phillips head screw holding the button in place. The cover release button can then be removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hannah Pate
회원 가입일: 01/30/15
1,742 평판
안내서 7개를 작성함
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S1G1
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 3,539
