주요 콘텐츠로 건너뛰기
Logitech M215 Scroll Wheel Replacement
필요한 것
  1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Scroll Wheel Replacement, Remove old battery: 2 단계, 이미지 1개 중 1개
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Scroll Wheel Replacement, Button Plate: 3 단계, 이미지 2개 중 1개 Logitech M215 Scroll Wheel Replacement, Button Plate: 3 단계, 이미지 2개 중 2개
    • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
  4. Logitech M215 Scroll Wheel Replacement, Pry off buttons: 4 단계, 이미지 2개 중 1개 Logitech M215 Scroll Wheel Replacement, Pry off buttons: 4 단계, 이미지 2개 중 2개
    • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
    • The button plate should be able to be completely removed at this point.
  5. Logitech M215 Scroll Wheel Replacement, Scroll Wheel: 5 단계, 이미지 1개 중 1개
    • Use the prying tool to remove the scroll wheel. The wheel is held in place by two pegs which stick into the plastic holder.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hannah Pate
회원 가입일: 01/30/15
1,742 평판
안내서 7개를 작성함
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S1G1
4 회원들
안내서 28개를 작성함
6가이드 댓글
glad I was able to find this info on disassembly. Gave it a good cleaning and works better than it did before. Had the Phillips screwdriver. and used another small screwdriver and a small pocket knife to pry with. Be gentle - doesn’t look like it would take much force to break those plastic bits.
carmenanddave - 답글
Thanks! Mouse wheel windows were blocked by lint.
levensonjb - 답글
Very useful. Cleaned coffee out of mouse wheel spokes/windows and off of chipboard. Works better than before. Thanks!
OGrady Watson - 답글
Probably the BROWN stuff wasn’t coffee, I too cleaned the spokes/windows. the brown stuff is oil from out hands which lands on scroll wheel, then by heat gets transferred to the spokes. touch a finger on the mirror, the fingerprint on the mirror is because of OIL on hands. it is the same oil in that mouse wheel spokes.
tejaswin_jain -
There is a spring here connected to the wheel. Seems to be the thing to give tactical feedback when scrolling. It fell out when I took out the wheel not 100% how to put it back
Dan Molnar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 86
전체 시간: 13,954
